1977 50hp Mercury flywheel removal
garyd13
best way to remove flywheel without damage. i am currently replacing original wiring Thanks
gm280
garyd13, :welcome: to iboats. Glad you could join us...
The usual way to remove an O/B engine's flywheel is to use a flywheel puller (harmonic balancer puller) that has three legs. Each leg is bolted into the three threaded holes on the top of the flywheel. And the center bolt is then tightened down until the flywheel breaks loose.
There are many threads on these forums that cover this subject in great detail. But some times flywheels are very stubborn to come off. So it takes some effort to remove them. First thing you need to do is use grade 8 bolts and thread them in about 1/2" into the flywheel. If you go in too far it will thread through and possibly damage parts underneath the flywheel. So only thread the three bolts in only so far.
And once you applied all the torque you can to the center bolt, take a hammer and whack the center bolt to help break the tapered flywheel off. Some times it takes a lot to remove them. And when they do break loose, it sounds like the flywheel has broken. But it is just the sound of it breaking loose.
This is the type wheel puller you need to be using with grade eight bolts. If you try to use other bolts, I can guarantee you they will either break, or strip. Been there and done that! So save yourself some time and headaches and buy grade eight bolts to start with. :thumb:
garyd13
Thanks gm280 your help is appreciated just learned of this site yesterday !! Think it will be a great site Thanks again
The MERCURY flywheels use one big internal thread for use with a puller.---Some of their flywheels can be pulled using 2 bolts.--Remove 2 of the bolts on the flex plate and use those to pull it off.
tommarvin
Ensign
All I know is don't use the three jaw puller,
We had to heat around where the flywheel and drive shaft meet with propane for two minutes gently tapping drive shaft every two seconds it finally broke free.
Are you replacing the wiring on the trigger and stator?
CDIelectronics.com is the king of ignition parts.
Free factory service manuals at www boatinfo.no/lib/library.html click make
