1977 35 hp Evinrude shifting
ripper1961
Took the lower end off my motor. Impeller looks good, seemed to be low on gear oil. Splines all look good. My question is how easy should it be to move the shift rod up and down?003.jpg002.jpg
nwcove
Re: 1977 35 hp Evinrude shifting
have you tried rotating the prop while you move the shift rod? you should be able to pull/push by hand, but it may seem tight.
ripper1961
Tried rotating prop shift linkage will move only slightly.
F_R
Honorary Supreme Mariner
Normal. There are detents in there to make it snap in and out of gear. You have to apply considerable pressure to overcome the detent spring and make it "snap".
ripper1961
Thanks for the info. I will put it back together and head to the topside .
