I have a 1977 25hp tiller steer. This motor idles great. It will run fine when in gear at slow speed, but when you give it a little more gas it sputters, bogs down and dies.
At the same time that I started experiencing this problem, I started having a hard time cranking the motor in the mornings when it is cold. It used to be 1-2-3 pulls and running, but now it is 15-20 pulls and running. It will start on the 1st pull after you shut it off.
I just recently had the intake gasket replaced twice. The first time, the shop did not torque down one of the bolts to the power head and it fell out and busted the new gasket after about 2 hours of running.
The bogging problems started after 30 min. of running from the 2nd gasket replacement.
