1977 1150 Exhaust Cover Leaking
Faztbullet
Yes he means the crankshaft seals. You will need to remove powerhead and lower end cap to replace them. Also only use the OEM black/green silicon impregnated gaskets as you never really want to use silicon from a tube to seal leaks.If you use the aftermarket grey gaskets use a thin coat of aviation gasket sealer(peanut butter) only.
