saltwaterbluefish
- Dec 14, 2010
- 156
I have a 1977 115 hp johnson outboard. A classic i know..lol.. I was hoping someone could help me with an issue i keep having. After I crank up and let her idle for 5 minutes, when I try to go to full throttle the engine cuts off or seems like she isn't getting enough gas. I usually put her back to a lower speed (5 mph), puddle for a little longer, and then she usually will allow me to go at WOT without cutting out. While she is idling she doesn't sound rough, so i don't think it is a carb issue.
Last time I took it to the mechanic he didn't seem that concerned, but did not want to really explain why it was doing that. The compression on the cylinders were all around 10of each other and I just replaced the fuel lines and tank.
Any thoughts or suggestions would be appreciated
