1977 115 evinrude choke
verne1972
i just recieved a electric choke and have no idea how it connects to the carbs. can someone take a picture and post it? I have all the parts, i just am having a little trouble lining it up. Thanks again :confused:
Dhadley
Re: 1977 115 evinrude choke
I don't happen to have one of those motors but you can look at the parts diagram at shop.evinrude.com. Take a look and let us know how you make out.
Dhadley
Have you got the solenoid in the bracket? Then the plunger in the solenoid with the spring under the plunger? Then there's a long, thin link up to the choke plate on the top carb.
verne1972
i have the plunger, with the spring under it, i also have a thin bar comming from the lower carb that attaches to the plunger. i am not understanding where the actual solenoid mounts. it has a bracket around it, unfortuantly, on the side of the manifold, is the oly place i can see it sitting, but in interfears with the linkage in both holes. am i missing a bracket? i bought the entire unit (carbs, cover/manifold, and choke off e-bay) there was a piece of broken bakolite on the manifold/cover in one of the three holes on the side the choke is mounted.
F_R
It mounts to the rear of the air silencer base plate. Long skinny spring link goes up to the top carb choke. An adjustable link goes between the two choke arms.
'76 and '78 should be similar. Try those on the website.
verne1972
no luck yet, plenty of parts diagram. no complete pics....
BigB9000
I know they changed the mounting and location in 78.
76 should be the same.
I parted out a 77 and a 78 115, ill see if i still have the pics.
I might even still have extra parts if you need anything.
let me know....
verne1972
thank you. i wont know if i need any parts untill i can see some pics. but thanks for the offer, ill keep that in mind.
BigB9000
Can I see pics of what you bought, and your engine?
that may strike my memory of how it goes together
Ok, you should have 2 rods for the carbs right? (linkage I guess you could call them)
One is just one rod, bent at each end to connect to the carbs.
the other one should be 2 rods, connected together using a small metal bracket with a little 'nipple' coming off. That rod controls the 'butterflys' or choke plates
then the choke plunger should have a little rod/spring coming off of it correct?
The air cover/silencer I believe has provisions to hold the choke solenoid. But I dont think it actually mounts there. I believe there should be a strap around the solenoid itself, with 2 screw holes, that attaches to the intake manifold itself, not the silencer
F_R
Here ya go, this is the best I can do.
BryaninFL
Anyone know where to by this Choke Retainer Spring as noted in the picture attached above, My spring is not right and won't fully close the choke like its suppose to.
F_R
Brandon is not exactly out in the boondocks. There are Evinrude dealers reasonably close to you. Give them a visit, they can get you whatever parts you need.
BryaninFL
I just thought there would be place besides Shop.Evinrude.com to buy it online.
Anyways I just ordered it through a local Evinrude dealer for $7 and will receive it tomorrow.
