1977 115 evinrude (cannot fix miss) help please
dejcantan@aol.com
had problems last year with engine running for about 5 minutes idling fine, then breaking up and missing terribly. rebuilt carbs, fuel pump,4 coils,plugs,power pack,gas lines and fittings and bubble.never got it running properly,parked it until now. fresh gas/oil,good cleaning has been done. the engine will run fine for a few minutes,then breaks down. tried pulling wires, and found that the motor runs better on three cylinders with the #3 plug wire off.when the #3 wire is reinstalled, it starts spitting and sputtering and missing.ran compression test on all 4, and tests ran from 115 to 120 on all. please help.
ezeke
Re: 1977 115 evinrude (cannot fix miss) help please
Try to isolate the problem, but it sounds like a coil breaking down. First switch the spark plugs to make sure one is not cracked. Then switch the #3 and #4 coils to see if the problem is the coil.
R.Johnson
If you can get your hands on a peak reading volt meter, do a running test on that #3 sensor. You state that you have a new pack, and coils. There is only one cylinder acting up, so not much left but the sensor. A peak reading volt meter can be a pricey item, and not everyone has one. Just can't think of a way to isolate that #3 sensor. Lets' see what the other guys' come up with
Knightgang
I am having a very similar problem with my '85 Suzuki DT115. I just rebuilt carbs and fuel pump, new fuel bulb and seafoam in tank (gas was only about 3 weeks old) and still have the problem, just not quite as bad.<br /><br />I was thinking about swaping coils to see if my dead cylinder changes. My manual has resistance specs for my coils, I am going to test them next and see. If I figure mine out, I will come back on and share my sucess. I know mine is Suzi and your a Rude, but an outboard is still an outboard.<br /><br />Good luck and keep postn'.
kenneths
But an outboard is just an outboard????????<br />Sounds just like the engineers at U.S.Marine years ago....... :D :D :D
Bob in Calif.
I had the same occurence and found the problem was one of the coil ground wires was not properly grounded. Make sure there is no paint or corrosion between the ground wire connector and the block and that the coil bolts are properly torqued. You might want to do a compression check also, just in case.<br /><br /> ...Bob in Calif...
OBJ
Hi Don.....Don't ya' just love intermittant problems?<br /><br />Bout' this time I would say get the hair dryer out and start heating things up. Sounds heat related. You could pop the flywheel and take an ohm meter reading acros each coil in the timer base. Log each reading and see if #3 is any different. You'll need a low setting to get anything but infinity. Once ya' done that, apply the hair dryer to the timer base and monitor the lead to #3 timer base coil. If it changes or opens, ya' got the bad boy. Also you might want to flex the harness the lead is in on the chance a wire is broke. And as posted from Bob in California....check those grounds.<br /><br />Good Luck.
moonfish
have you checked your choke to make sure it's operating fine? if it runs fine then messes up, maybe the choke is stuck closed, or partially so? Did you replace spark plug wires? The wires are old and corrosion gets to them. Are the wires on the wrong cylinders? It's hard for me to envision it running better with one unhooked, but i know little.
K Hultgre
Any chance the plug wires are arcing across to each other, #3 sparking more often than it should causing misfires. Separate the plug wires or add a layer of electrical tape to help isolate.
