1976 srv 240
Re: 1976 srv 240
^^ Doing a full restoration!!
Ayuh,.... Welcome Aboard,... For the Motor/ drive, or the whole boat,..??
For hull wirin' there's generic diagrams in the Electrical forum,....
76sundancer
Re: 1976 srv 240
I haven't located anything. I've got everything working on the boat but I just want to confirm that I have everything wired correctly. Mainly at the dash. Any ideas?
76sundancer
Re: 1976 srv 240
Yes dash wiring is what I'm looking for. I looked through the link but mine is an OMC 235
76sundancer
Re: 1976 srv 240
Thanks again! I checked but didn't find what I'm looking for. At the dash I have 10 fuse holders and 8 toggle switches. I have replaced the fuse holders and have it hooked up. Everything works but I do not know the correct size fuse to use. Currently all 30amp. There has to be a diagram or chart showing the layout. Thank you a lot for your help!!
NYBo
Re: 1976 srv 240
Fuses are sized to protect the wiring, not the device. Since your branch circuits are probably 16 gauge, use 10 amp fuses, max. If you have a high powered audio amp or other high-draw accessory, it should be wired directly to a battery (or the battery switch) with wiring and fuse sized accordingly.
76sundancer
Re: 1976 srv 240
If they all work with a 30 amp fuse going to a lower amp fuse won't matter? The first fuse is wired directly to the 'switch/ battery' and then jumpers go to the next fuse.
