1976 Merucry 40hp single click noise (wont start)
timbo471
I have a 1976 mercury 402 40 hp. When I turn the key, it will not turn over. It makes a single click noise. I know it is not the battery, because I took the battery from my truck and tried it. Plus everything else on the battery still worked.
I believe it is the starter or the starter solenoid, I just want to make sure so I do not spend money on a part I do not need.
Any advice would be greatly appreciated.
Thanks
Tim
latin monkey
Re: 1976 Merucry 40hp single click noise (wont start)
check for loose connection on solenoid
timbo471
Thanks, I will try that shortly..
latin monkey
the same thing has happened to my old merc numerous times and it was always bad connection on solenoid. i've replaced it a couple of times but they just arent built very well
timbo471
I lowered the motor, without hooking up the gas. Just wanted to see if it would try to turn over. It now wants to turn over. I did not see any loose connections. So now I am very leery of taking it out on the water until I figure out what exactly was causing the problem.
Though I am pretty sure it has to be some kind of loose connections. If anyone has any other idea's what it might be. I would appreciate it.
Thanks,
Tim
