1976 mercury 85hp with out trim looking at a unit form a 1982 90 hp need help
domstaab
Hi I have a 1976 mercury 85hp without tilt and trim on it just manual lift I'm looking at a trim system off a 1982 mercury 90 hp I'm curious If this system will bolt up to my Motor or if I have to get a diffrent transom bracket. Any help would be great before I commit to buyingredients this system
jimmbo
Should fit without any issues. Just don't forget to remove/disable the reverse lock mechanism on the transom bracket before installing the T and T system
Chris1956
Is the PTT unit the two cylinders, external to the transom clamp? If not it will not bolt up.
Chris1956
OK, make sure to get the two trim brackets, 4 hoses, trim pump/reservoir, trim panel and wiring harness and the trim cylinders themselves.
