1976 mercury 115 pistons???
Shadow1234
I just bought this engine yesterday. My dad did a compression check on all the cylinders and all had 120psi except number 3 which was 60psi. So he thought no big deal replace that piston and good to go. Well we just took it apart and I now need to replace three pistons one is cracked one is burnt and the other number 3 is really burnt up. The pistons that came out of the engine are 3 ring pistons. And when i put the model number in on the internet to buy new pistons they are only 2 ring pistons. Did they just switch to 2 rings??
I have a couple of questions for you guys/girls on here.
1. Will the 2 ring pistons work?
2. What caused the pistons to burn up like they are in the picture my dad thinks it might be the timing.
3. 4 of the pistons have notches on them and 2 do not. My dad thinks that it has been rebuilt before.
4. What all do I need to buy? I need a shopping list. I am a broke college student trying to get out as cheap as possible but I do not what to cheap out on the engine so what ever needs to be done needs to be done.
P.S. if you need anymore information just ask.
Thanks,
Shadow
NO LIP
Crack
#3 piston
With lip
All 3 that need to be replaced
Chris1956
Honorary Supreme Mariner
Re: 1976 mercury 115 pistons???
Looks like they were running lean and have detenation issues. The 2 ring piston replacements can be mixed with the three ring original pistons. You will need to bore out any cylinder that is damaged and install an oversize piston and ring set. Shop around as pistons can be pricey. You should find some for about $90/each.
You must clean all carbs, rebuild the waterpump with gaskets, orings and impeller and wearplate, as well as set timing to factory spec, or you will have a repeat of this damage.
Shadow1234
Cool. Thanks for the info. Ill clean the carbs. And do everything you say to do here.
Faztbullet
Thats pre-ignition damage due to a bad trigger, replace it.
Chris1956
Hey Fazt, That 1976 motor has a distributor. Is it still the trigger?
arsenalpsu
I sent you a PM in reguards to your pistons.
Faztbullet
yep ..replaced about 30 or so over the years for the same issues..
