1976 Mercruiser 165hp Inline Six? What should I do
Status
Not open for further replies.
thormxryder
New to I/O and I just bought a 76' Thunderbird Signa for 300 bucks with trailer for a project!!! Some of the hoses are disconnected and I figured out I am missing a Water Distribution Block. This hasn't been run in 5 years and has been winterized. My Main question is: Where should I start as far as changing parts/filters/plugs etc.... Any help is greatly appreciated as I am new to I/O and looking to get as much knowledge.
stonyloam
Re: 1976 Mercruiser 165hp Inline Six? What should I do
Go to church on Sunday and say your prayers;). Then call a reliable boat surveyor to look over your boat HULL, ENGINE and OUTDRIVE. Will probably be the best couple of hundred bucks you ever spent. Have them give you a complete report, then decide what to do. Let us know how it turns out.
Pete104
Maybe the church would want it!
Fordiesel69
Get the engine to run & circulate water first. If no cracks are found, and engine runs, move onto getting it tuned up.
ziggy
here would be a great place to learn as much as possible about your drive and engine.
thormxryder
Thanks for the help so far... I found a part I was missing (water distribution block) and got that put on and waiting til tomorrow to go through it some more. Any other help would be appreciated.
dubs283
yes, download and read the manual that zig was nice enough to post a link to
then you can identify what engine/drive you have, what seems to be wrong with it and then someone may be able to point you in the right direction
are you familiar with how a points ignition system works??
mechanical fuel pump??
take some time to look over anything hosewise that looks cracked or stiff and replace it with the proper style hose
same with wiring, battery, wood, etc...
learn how to pull the drive and inspect all transom assy components, replacing the water pump in the drive, pressure testing the drive
Fordiesel69
I have a spare 165 engine if you need parts.
thormxryder
Thank you dubs! I went and bought all new hoses today and I plan on just picking up another water pump tomorrow. And Ford I'll let ya know if I come across anything, considering you are in erie and im north of pittsburgh
Status
