Re: 1976 Merc 1500 Dead in the water!!! Help please!
Sorry it's taken me so long to update. I actually have it running good enough to use it some and have done some fishing as well as working on a couple pontoons for my neighbors. Anyway... here is where it stands now:
I've replaced ALL engine and control related wiring. New harnesses for interior and exterior. Ignition wires including all to and from the control box. I'm not able to get a tach signal from the control box but I do when I connect it to the stator. After I recieved it back from the marina it did run some what better than when I took it to them however they had the carbs set so the lower carb would barely open at WOT and they had changed the timing from where I had it set by the book. I also noticed that they had moved the timing pointer back to a position that was scribed on the alignment pin instead of actually bein on TDC. When I had taken it to them I had set the pointer via the dial indicated .464 prior to tdc as described in the manual. That put the pointer off to one side but still within the adjustment limit. Regardless after I received it backk from the marina I checked it all again with TDC and not the the dial indicator method. I ended up moving the distribnutor one tooth on the belt. I knew the distributor arrow was just a little off before however it was similar to some pics I had seen on these forum postings so I figured I was ok. Unfortunately here is my timing points:
idle - 4*
High idle - 8*
idle in gear 4*
Max timing - 28*
with these settings it starts hard and when I put it in gear I HAVE to give it some throttle or it will die. All carbs are 2.5 turns out on idle which works best for how it's set up so far. Typically when I hammer on it... it goes. Idle in water is about 800-1000rpm (sometimes up to 1200) in gear anywhere from 500 to 800 if it doesnt try to die. If I have it in gear and run it around 1000rpm it sounds like it's missing and the motor shakes a lot and smokes a lot however it never changes speed and seems to be ok running that way all day. Most of the time if I ram it to WOT it takes off however when it does the engine seem to speed up in stages and once its on plane it really pushes you back in the seat and the RPM rises very quickly. Not sure what the max rpm range of this motor is supposed to be however i'm getting about 5000 rpm at WOT and up to 5200 if i push the max trim on the motor.
Also I can make it run pretty well and not want to die transitioning between idle ouy of gear and in (for the most part) however I cant find that sweet spot with the motor cover on. It seems like it's starving for air with them on. I removed the baffle out of the hand hold area on top engine cover and that helped however it still performs noticably different with the covers on and is more difficult to tune. I have new needles and seats that I plan to put in sometime this week and at tha point I will adjust the floats if necessary. Do you folks suggest I set them by the book or something different? I seem to push a lot of fuel out of the carbs especially when I tilt the motor. Even without tilting the motor the fuel will leak through the butterfly shaft down to the next carb or into the water if it's the bottom carb.
I did find a quick and easy video to help set up the timing points out of the water however it didnt work for me as I had to adjust mine to tune it in quite a bit. Here is thge link:
How to Link and Sync Mercury 1150 Inline 6 - YouTube
I need to get this motor to where it will idle decently and transition from neutral to forward and reverse without it dying on me and not beating up my gearbox. I'm more worried about that than top end at least right now. Can anyone tell me what this motor's effective rpm range is supposed to be? Not that it matters a lot but I'm running 40:1 mixture right now just to make sure I dont burn it up.
I'm not sure if I missed anything but any help will be appreciated. I already apprecaite everyone's feedback up to this point. The good thing is I know the motor is not bad because there have been moments where is is VERY impressive with its accelleration however I cant seem to find the best of all worlds with it.
