1976 johnson starter drive drop out
mac2
I have a 1976 johnson 55 hp starter drive drops out just as motor starts to fire, replacement drive nla, took to auto ele. service he took apart checked and said it was ok. New battery,good power to posts on starter when keys is on, but will still drop the drive out just as the moter stats to fire.dont want to buy new starter and have it do the same thing.
Joe Reeves
Re: 1976 johnson starter drive drop out
Mac..... Check the top portion of the starter bendix drive teeth for excessive wear.<br /><br />More importantly, check the bottom portion of the teeth on the flywheel. There have been occasions where the teeth have been worn down at an angle at one area or another, causing the bendix to disengage. If this is the cause, unfortunately the cure is to replace the flywheel.<br /><br />Also, if the above is the case, where one has nothing to lose by trying, one could try having a machine shop restore the teeth to new condition. I've never seen that done but it's something to think about.
