1976 Johnson Seahorse 35 HP PROBLEMS!
daarnold82
Alright, I love my motor, but lately its been down and out. First, it has been "jumping" which I believe to be the lower unit clutch. What I cant figure out though it why it will run for 10-15 minutes (generally) at full throttle just fine and then all the sudden die. It will start right back up, but will only run at like 1/4 throtte...any more and it will die out. Is this something as simple as a fuel filter? I bought a Clymer manual for this motor (which stinks) and it doesnt even list a fuel filter part #. I realize there are different model #s of this particular motor, but can anyone help me out with what filter I should be ordering or if this is where I should even begin to start with this problem...Its so close to boat season and I dont want ot be straned on the lake anymore lol. Thanks!
Joe Reeves
Re: 1976 Johnson Seahorse 35 HP PROBLEMS!
If when that engine dies, and you still have spark (check it), I would strongly suspect a fuel restriction between the engine and fuel supply. It might possibly be a sticking fuel primer bulb outlet valve, or the following.
(Fuel Anti Siphon Valve)
(J. Reeves)
Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vaccum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve.
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
BoatBuoy
Not sure about your '76, but my '77 35hp has no filter other than whatever strainer is in the tank; and the strainer at the fuel pump. Remove the thumb screw on the fuel pump and remove/clean the screen. The symptoms, though, sound more like unvented fuel tank or other restriction. Maybe even a faulty fuel pump.
daarnold82
Thanks for your timely help guys! Now ive got somewhere to start.
