Nick Dobda
Thread starter- Joined
- Jul 3, 2017
- 5
Need help, ignition problems.
First, the back story:
Late summer 2015 driving back to the dock - engine starts to sputter, as if one cylinder is going down. A minute later, more sputter, two down. 30 seconds later, engine dies, won't start. Engine cranks, but it will not turn over. Paddle back to dock and park the boat until July 2017.
I had assumed it was plugs becoming fowl. I bought new sparkplugs, and a new 1000 amp battery thinking it would turn right over. No dice. Buy an inline spark tester, no spark on any of the 4 plugs. So it is an ignition problem.
I did some minimal research, found that disconnecting the kill wire (the easy check) out of the power pack does not solve the problem.
I called the local boat mechanic, he wants $85 an hour to diagnose. I think I can probably find a new pack for that much, but I want to verify that the pack is the problem, and there are processes on the internet to diagnose, but I need the process explained in laymens terms.
Can someone explain this chart(s) to me?
http://www.outboardignition.com/page40.asp
http://forums.iboats.com/forum/engi...test-cdi-power-pack-testing-a-helpful-website
What is DVA? What tools do I need for this check... a multimeter? A peak volt thingy (how much do they cost?).
I need the process really dumbed down and explained for me. Can anyone shine some light on whats going on with my motor?
Thank you!
Thank you!
