1976 Johnson 9.9 won't crank.
Turtleman76
My 1976 Johnson 9.9 was running fine two weeks ago. It would crank on the first pull every time. All of a sudden it wouldn't crank at all. I brought it home and cleaned the carburetor really good and still no crank. All spark plugs have been changed. Just out of curiosity,I switched the spark plug wires around (reversed them) to the opposite spark plugs and the motor cranks on the first pull, but won't idle down. I am wondering why it will crank when they are reversed but not when they are right.
oldboat1
^^agree. Additionally, check spark on each lead with an adjustable tester, and wouldn't hurt to check compression as well. Need to pull off the flywheel -- have points on that motor, so good idea to clean and regap those along with checking key. (Torque to spec. when reassembling, but can recheck spark before fully tightening it down. Give the flywheel a quick spin or two by hand.) Look for about a half inch spark, then back down until you find it -- maybe 3/8 inch on the '79. Spark has to be sharp -- should be no difficulty seeing it (often hearing it).
not sure if your carb cleaning is a help or hinderance at the moment. Sure doesn't hurt if done well. Idle mix needle needs to be right, along with the sync. Check the gas for water or other contamination.
Just so you know, cranking usually refers to an attempt to start (pulling over in your case) -- so "cranks well but won't start" makes sense to folks.
