1976 johnson 9.9 hard start, rough idle (revs up high and down)a
jessee
Hey guys new to this forum and new to working on boat motor but work on old harleys from the 5o's all the time and good at it.
I recently bought this motor and would barley run, hard start and die often. was horrible. fount the connections on the gastanks were sucking air and gas line was fucked. so i changed all of that and it improved. It now started alot easier and ran better as i tried to lean out the carb on the lake and it ran way better. but couldnt troll at a slow speed.I took it home found the fuel filter filled with corroded rubber. cleaned it, put carb back to factory settings (1 1/2 turns out) got it started and it would run, then die after 30 secs to a minute. took it home put carb rebuild minusjets, but they looked clean so i put in a new float and gaskets and o rings. all new gas lines and fuel pump. row it will stay running but will idle ok, then rev up super high then drop down. but stay running? what should i look into next and how should i dial in carb better.
I also put new coils, plugs and water pump, ran seafoam a couple tanks ago. run premium gas and 50:1 mix.
ill post a video in a bit
gm280
First jessee, :welcome: to iboats. Good to have you join us.
Seems you basically covered everything already in the could be items. Reading how you had some rubber particles fill the fuel filter, I would suggest you still have a fuel delivery issue. And therefore look at the carb again. In some of those little passages, it doesn't take much to plug them. So I would go over the carb again as my next option, especially on a smaller OB like you are working on. Also, make certain your tank is clean too. JMHO!
Sunken Ship
I second GM280. There are five tiny holes (a sewing needle will pass through these barely) in the carb on my '75 40hp that permit fuel to siphon as air flows through the carb. Tiny particles like those coming from the fuel pump diaphragm will clog one of those.
In addition there is no filtering mechanism located between the fuel pump and the carb unless someone added one.
OptsyEagle
One other thing to consider is the spark plugs. That model of motor (1974-1976 9.9/15Hp) really hates Champion spark plugs. I don't know what type you are using but I would recommend NGK B6HS plugs. That motor will never be good at trolling. They don't make a spark plug that will allow much trolling before they foul. If you use the NGK plugs, you can get a couple years of normal use out of them but with Champions, you might not get any use at all. One of the symptoms can be intermittent cylinder loss. Bogging and surging.
Search this site for spark plug issues on your motor and search Leeroy's ramblings. I think it has something to do with the design of the cylinder head in combination to the lower voltage put out by the ignition system, but in any case, my best recommendation is to ensure you always use NGK plugs and get a new motor if you plan to troll a lot.
