1976 Johnson 85hp not running on #4 cylinder
philwilliamson
Hi All. I have a 1976 Johnson 85hp that is not running on #4 cylinder. While motor is idling or in fast idle, plug wire on #4 can be removed without the motor changing any. Removing any of the other sparkplug wires from the other three cylinders alters the sound/speed of the motor. Spark has been checked with inline spark checkers and is present on all four cylinders.
I swapped sparkplugs between #2 and #4 but previous problem stayed on cylinder #4. I swapped coil wires (orange wires) on #2 and #4 at the powerpack and moved plug wires from #2 to #4 and #4 to #2, with no change in the motor when plug wire pulled off #4.
I then swapped the sensor wires in powerpack for #2 and #4 coils (left the orange coil wires in the "swapped" positions) (and put plug wires back to correct cylinder) with no new results when plug wire is pulled from #4.
With plug out of #4, when motor is turned over, there is gas vapor blowing out of the cylinder, so it is getting fuel. And looking in cylinder, the piston is moving.
Carburetors have been removed and totally torn down twice and have found nothing inside (super clean). These were just rebuilt with new parts a few months ago,including fuel lines and primer bulb line from gas tank. Only non-E fuel is being run with Johnson brand oil mix. I looked down the intake while carburetors were off and ports were clean for all cylinders. Flaps looked fine also. While motor is running, gas is flowing in each throat for each cylinder.
I disconnected the gear shifter lever on side of motor going to the foot (so as to not damage the lower end/prop since it is not in water) so motor speed and timing could be advanced normally from the shifter box at the helm, and when motor is reved, you can see a stream of gas going into the throats.
Compression for all 4 cylinders are : #1 (100#) #2(110#) #3 (110#) #4(100#).
I am my wits end. My daddy always taught me if you have fire, fuel, air, and compression, a motor would usually run, but this one is giving me fits. Any advice would be appreciated.
Bob_VT
Use an old fashioned timing light and use that to check the spark. With the motor running you should see a bright flash from the light.....steady and rhythmic. The bad cylinder if it shows NO flash could have a bad coil and if it is an erattic flas them possibly a bad power pack. Sway the coils around and see if you can get the problem to follow ....if so then it is a coil problem.
