1976 johnson 85 hp seahorse wont start
Kathrynterrysmith
We have checked battery tested stator rectifier coil starter and wiring. I bought the boat two weeks ago and the people who had it before let it sit for a year and half with out cranking it. But we can't get it to start it will try and turn over but that's it. We have also tried jump starting it and it will not crank still can anyone suggest something that we might have not tried thank you ahead. Of time
oldboat1
Clean up the battery connections until they shine, including the solenoid and starter. Pull the plugs out and see if it cranks w/o compression. Do a compression test.
ondarvr
So that everyone is using the same terms.
Cranking and turning over are the same thing, starting is the next step. You said it was trying to turning over, then said it wouldn't crank, what I get out of it is that while the starter engaged and tried turn the motor over, it wouldn't, and then even when you jumped it it still wouldn't turn it over.
Oldboat told you what to try first.
Gary H NC
No way I would run the engine until the carbs are cleaned....If it does have good compression a clogged carb will sure wipe out a cylinder once you do get it to start.
If it will not even spin over pull the plugs and shoot some PB Blaster in the cylinders....without the spark plugs see if it will turn by hand.
emdsapmgr
Possible the starter brushes are bad. You may want to replace the brushes in the starter. Cleaning it and re-lubing it along with the new brushes should have it working like new. A starter overhaul is not rocket science on this engine.
Kathrynterrysmith
Just to update I have done carb checked coils and spark plugs battery stator trigger power pack rectifier starter but not getting fire to the power pack any suggestions
Michawilden
You wont get the proper voltage reading from the stator? of you dont have spark on any cylinder? Maybe the kill wire, black and yellow grounds out somewhere. See if you get spark when you disconnect this one.
emdsapmgr
The power pack depends on the correct signal from the timer base (when to fire) and the stator (power.) Both of these devices put out specific voltages when the engine cranks. What were the readings when you tested both of these devices? (were the voltages above the condemning criteria?)
