Dwickham86
Thread starter- Joined
- Jul 6, 2018
- 1
Hey guys, I bought a boat with a 76 Johnson 75hp stinger on it, ran great and was used this year before I bought it, took it out to the lake and it overheated on me, started losing power so I shut it down and it started smoking a bit. Got it home and did a compression check and it's at 120 across all cylinders. I did replace the impeller before I took it out but there's no tell tale on this motor so I had no idea it wasn't pumping water. So I guess i will replace the stat and do a whole water pump kit, is there anything else I should be doing while I'm at it? I obviously want it to be reliable for the family, I'm fairly new to boats and I guess without a tell tale I'm pretty nervous about over heating and frying the motor. Thanks in advance and great forum by the way!
