1976 Johnson 70hp - Long warm up
Wet Stinky Dog
Cannot accelerate before idling around for 10 minutes or more. Has anyone else had this issue? Just recently bought the boat and have had this issue the 3 times we have taken it out. Any ideas? Runs good after long warm up.
Honorary Supreme Mariner
Top of cylinder head.-----Check thermostat and poppit valves.-----Compression test is also a good idea.-----Check spark on all leads.
F_R
Watch the throttle linkage on the side of the motor while somebody slowly operates the control (or disconnect the cable and do it yourself at the motor). As the cable moves the lower end of the tall vertical shaft, the upper end should move along with it, moving the timer base as it does (the upper end is moved by a spring). This should happen with very little movement of the carburetors' throttle shafts. The carbs shouldn't move much until the timer base moves to full advance.
If the timer base is sticky and the carbs open too soon, it will fall on its face and probably stall. If this is what is happening, the cure is to clean and properly relubricate the timer base mounting.
