1976 Johnson 6hp timing plate slop (how much is too much?)
Mark Lamb
Hi guys, I am a little OCD about things being right on this motor. Upon removing flywheel to inspect points and coils, I notice slight side to side play in the timing plate. Figuring this would affect proper opening/closing of points I bought a new (not used) retainer ring per info found on this and other forums. No change. I have also read that some play is normal but would be interested to know how much is too much. Thanks in advance.
OptsyEagle
With the flywheel off, move one of the points into the set position and then grab the armature plate and attempt to move it laterally. If you can see the points opening or closing more then 0.005 inches or so, then I would say that is too much. Turn the throttle to another position and do that test again. You can also do a measurement and see if the point gap changes more then a few thousands of an inch, at the different throttle positions. If it does then the lateral movement is a bit much, in my opinion.
Mark Lamb
OptsyEagle, what would you recommend as a solution to the excess play? I have read here about molesting the retainer ring and/or the thin bushing attached to bottom of timing plate. Seems to me that unless the suggested indenting are identical and perfectly symmetrical there might be problems with points opening equally. What say you?
Mark Lamb
BTW, I have the factory service manual on the way in the mail. Impatience rules me.
OptsyEagle
This was kbaits method he gave me for a 1976 9.9 Hp. I imagine it would work for yours as well It fixed mine.
Armature plate is held onto the retainer (below armature plate bearing and support ring) by 5 phillips head screws. Loosen all of 'em and pull their threads up into the armature plate itself, which un-hooks it from the retainer. Lift the armature plate off the 'boss' at it's center (boss is on top of powerhead w/crankshaft going through it). Now, pull that plastic armature plate bearing off of it's holder (support ring) and set it aside. Place the armature plate back onto the 'boss' and check lateral play.. turn a bit and check again. If it moves laterally, what you do next will take up the slack space. Again remove armature plate and look at the 'boss' on top of powerhead. It's round, and the bearing surface is about 1/4" in height. Take a sharp centerpunch (or a screw, nail, etc) and 'peen' 4 spots halfway up the height of the sides of the boss at the 12, 3, 6, and 9 o'clock positions. What you're doing is making a little 'wave' of metal rise up around your punch marks, and that metal will take up the slack space between the 'boss' and your armature plate's center bearing surface. Start w/small 'peens', replace armature plate and check play (also, turn the armature plate to check for too much binding). If it still has play, peen the same exact spots again, and re-check play until there's no play left. Don't peen so much as to make the armature plate bind too much when turning(creates stiff throttle).. a little resistance is fine.
Now, reassemble. *The plastic armature plate bearing ring is dry fitted.. wipe all grease/oil off of that bearing, it's support ring, and the underside of the armature plate where it rides before reassembling*. Also, you can use needle nose pliers to pinch the bearing ends together for reassembly.
The 'boss' isn't a dry fit. I use white lithium grease on the boss (sparingly).
F_R
Honorary Supreme Mariner
Get yourself a part number 580871 Armature plate kit. It includes a re-designed armature plate and improved mounting parts. It was developed to cure that exact problem and give long life. It also fits down lower on the crankcase neck to rotate on the un-worn area. You MAY have to drill and/or tap a screw hole to make it work on the 6hp...or maybe not.
