1976 Johnson 6 hp not getting full power
mitchellbrink81
hello,
I just bought a johnson 6 hp I already cleaned the carberator gave it new spark plugs and it runs great but when I put it behind my boat and put it in forward it is absolute not getting full power it does not even look like my 3 hp yamaha
can someone help me?
nwcove
Re: 1976 Johnson 6 hp not getting full power
get yourself a sparktest tool ( they are cheap!) sounds like you are only running on one cyl. you can confirm it running in a barrel by pulling one plug wire off, noting how the engine responds.if it stalls you found your trouble. if not, put that wire back on, and pull the other one off. if its running on one cyl, you will quickly find the bad one.
mitchellbrink81
I looked at the spark and they are bove good now i just looked at the compression by the upper cylinder it is 70 psi and the bottom cylinder has only 25 psi maybe the piston rings are worn what can it be else?
SeaKaye12
You can hope that it's the head gasket. And you would probably be correct.
mitchellbrink81
hello,
I just had a look and there was a little hole in the head gasket and the gasket from the thermostat is completely worn wen i want to pull that one off the cylinder head broke:facepalm: so now i just have to wait for a new cylinder head and he is ready to go
