Re: 1976 Johnson 55hp two cylinder will not fire
Hi. I thought I replied to your question, but I may not have posted correctly. To repeat, the rectifier has nothing to do with ignition, only charging the battery.First check to make sure your grounding wire is not grounding. I assume you have a remote control, check the key switch. Check all the motor connections from the stator to the powerpack to the coils for bad connections. The stators on these rarely fail. 99% of the time with weak, or no fire, or fire on only one cyl, it's a defective powerpack. How good of spark do you have when you have it? My 55 throws a wicked spark, it should jump atleast 1/4-7/16 gap. Most of the tests you can do with cheap VOM. some tests require a DVA adapter. There is a website called CDI electronics that is pretty helpfull. Once you get this motor running right, it will be pretty much bulletproof. Good luck to you sir.
