FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
iam trying to put a water pump kit in 76 johnson 40 hp i got silver plate and 2 .do i put a gasket on both sides of plate ,water pump was stripped down when i received it ,thanks
Not to sound dumb, but did the key slip out of place? No key=no turning impeller. I have had various 70's era outboards, and have not seen a gasket on the pump floor.
Could the impeller hub be bad? Those systems are not complicated. If the driveshaft is turning, the impeller is turning. If the water tube is not blocked, water should be moving.
