i have a 1976 2hp johnson, i did all sorts of work on it. replacing water impeller, fuel line, clean fuel system, etc. I had it running perfectly in a bucket. The next day when i took it out on the lake it was bogging down when i started and wouldnt excelrate. so i took it home took everything apart and saw that there was water inside of the cylinder. so my question is if this is some sort of gasket problem? i think the water cooling system might might be leaking somewere. thank you, Ryan
