Hey all,
I've just signed up as a member, but I've been through countless threads and topics with and awesome amount of success, until recently where I've become stuck. I have a 1976 johnson 115 v4 motor, in austin texas with daily temperatures averaging 80-100 degrees currently (potentially useful information for my issue). I am a car mechanic, and have worked on many carburetors, but not many 2 strokes let alone marine motors.
I have a no start condition, and I can't figure out why. I've had a few stints of the motor starting and working well (on muffs), with a minor dry sneeze on cylinder one, but since the last time I've had it running I can't get her going again. Here's the details:
115PSI compression on all cylinders, new powerpack, new trigger (please keep this in mind if my timing might be messed up!), new coils, new spark plugs, new starter, rebuilt carbs with new floats and kits (old jets, but welsh plugs were removed, cleaned and replaced), new clean mixed gas (50:1), with a new fuel pump, new lines, in line filter, new impeller... maybe it would have been easier to list the things I haven't replaced, haha, most of them were for good measure, and not for fixing the no start. As I had it running last season with a mostly " 1976 stock" setup.
The engine turns over quickly, my timing light shows each wire putting out an abundant spark to each plug, and when I remove the plugs after the no start they come out wet and smell like fuel. So I have fuel, spark, and compression... is this thing defying motor concepts?
Here are my questions, are the plugs getting too much fuel? Would my timing light show the plugs sparking even if they were fuel fouled? Is there a chance my power pack is bad, by sending out the wrong timed spark? Or do they not work like that? I have a dva adaptor if anyone requests some numbers. Please enlighten me or even throw out some things from y'all fresh minds, I think I've about exhausted my ideas.
I appreciate your input, and please dont refrain from asking the dumb questions, I could have missed anything at this point!
Dan
Dan
