1976 johnson 115 hp v4 no spark
Status
Not open for further replies.
timberwolf 135
hi
i am back again 1 cyl.of my 1976 115 hp v4 has no spark is their a way to test a coil or the power pack the power pack part # is 581895 i an not sure of the coil part #
thanks bill
mikesea
Re: 1976 johnson 115 hp v4 no spark
easiest is swap the bad coil with one that is firing,make sure all connections are clean and tite including ground
timberwolf 135
ok changed #3 coil wire with # 4 in the power pack that changed the coil that was firing to a non firing coil must need a new power pack is their any thing else i need to check
thanks bill
wilde1j
NO SPARK OR INTERMITTENT SPARK ON ONE OR MORE CYLINDERS:
1. Disconnect the Yellow wires from the rectifier and retest. If the engine has good spark, replace the rectifier.
2. Check the timer base resistance and DVA output (see NO SPARK ON ANY CYLINDER above).
3. Swap the timer base wire sets (swap the #1 & #3 pair with the #2 & #4 pair) and see if the no spark problem follows a timer
base wire.
4. Check the DVA output on the Orange wires from the power pack while connected to the ignition coils. You should have a
reading of at least 150V or more. If the reading is low on one cylinder, disconnect the Orange wire from the ignition coil for
that cylinder and reconnect it to a load resistor. Retest. If the reading is good, the ignition coil is likely bad. A continued low
reading indicates a bad power pack.
5. Visually inspect the ignition coils for burned or discolored areas and cracks in the casing (indicating arcing inside the coil).
6. Swap the ignition coil with one that is sparking correctly
You may need a DVA adapter. Like this:
http://www.usatoolwarehouse.com/usatoolwarehouse/ESI-640.html
timberwolf 135
hi
the info on on spark any cylinder
is for a 1978 - 1998 this is a 1976 will the spes.be the same also i have a plug question the johnson owners book i found for this motor list the plugs for this engine as 77jc4 not ql77jc4 champion list the ql77jc4 as a cid plug is this what i should use or should i use the 77jc4
wilde1j
The info is for '71 - '78 screw terminal pack motors.
The BRP Evinrude website doesn't show a 1976 115HP was made that model year. They show 115HP Johnson in 1975 and 1977.
capmorgs
1994 Evenrude 50 horse motor
No fire I have changed the plugs & plug wires. Any suggestions. Could it be the ignetion coil. Is it easy to test?
ezeke
It won't fire unless it's turning 300 RPM. Test for spark with all of the plugs removed so you know that you are reaching that RPM. See the troubleshooting steps here: http://cdielectronics.com/InstallSheet/113-1731.pdf
The 1976 115 Johnson was left off the BRP list, but it definitely existed. Use the 1976 Evinrude parts catalog - everything is the same except the paint and the upper cowl.
The 1976 Johnson V4 has the newer ignition components with the black ignition coils.
wilde1j
capmorgs, you'll do better starting your own thread.
Status
