1976 evinrude trouble! HELP!!!
Connorlawson_21
I'm 16 years old and just finished restoring a 1974 mfg niagara as my first boat. On the back it has a 1976 55hp evinrude this is what I'm having trouble with. Here's the problem, I took it to a marina because I would go out on the water and it crank right up and run real good then due done to a speed just above idle. So I took it to a marina and they out in a new carb kit and cleaned it and so on. But the problem is still there! Now I know it should go faster than about 15 miles per hour it's the max amount of horsepower you can have on it! Please help me solve the problem I really want to get out and enjoy my boat !
gm280
:welcome: Connortawsom_21 to iboats...
Okay so many things to check. I take it this is a single carb engine. They may have rebuilt the carb (and then maybe not), but what is the compression on the two cylinders. That would be my very first test. If they are good, I would test the spark on the engine with a spark tester. They sell them at most any auto parts store really cheap too. If you can have each cylinder's spark jump a 7/16" gap with a good blue color, your spark and ignition is good. Make those test and report back here for us to evaluate... Don't give up!
This is what you are looking for...
oldboat1
sounds like you are above idle if doing 15mph. It's possible the hull has water in it -- not sure if that model has a floor in it, but might be water logged under there. It can be a problem with old hulls, but can be remedied. Also, when up on your trailer, check the bottom of the hull and see if it is straight and smooth from front to back. Good rig.
Connorlawson_21
Alright will do I'll go out and and buy that stuff in the next hour. And it has two carbs, and also one question could it be an impeller issue because in most old outboards I see a steady stream of water come out of the engine but mine doesn't do that very well
nwcove
im with gm280, sounds like it may be dropping spark on a cyl after things get warm. trouble shoot in a systematic fashion, just dont go throwing parts at it !
oldboat1
think the shop that did the carb work ran the motor after it was reassembled. Don't fix what ain't broke. If you think the rpms aren't getting high enough, pull a plug wire while it's running and see if there is a change in operation. If you pull a plug boot off and get no change, that plug isn't firing. But with a first renovation, don't discount extra hull weight.
bonz_d
Compression seems a little low. Any idea as to how long this was sitting unused? The early 50-55hp didn't have a water tell tale. My 1975 50hp didn't. Don't suppose there is a tach in the boat is there? Do a spark test and a drop test as suggested above. Doesn't sound like a normal fuel problem to me.
