Not easily. The 73-76 thru most of the 77's were the first design. The pistons were all exposed outside the transom bracket. The 77 140's were the first to get the new style where they are hidden between the brackets. ( the first of the current models.) The transom brackets are different as is the swivel bracket. Not sure that all your 78 stiff will adapt to the 76. You may be better off buying a junk 76 135 with a good trim unit and transplant it onto your 85. I ran a 76 with trim for many years. Looks odd, but worked just like the new ones. Had no problems with it. You can see some of the differences on the factory exploded parts diagrams at the factory website: epc.brp.com The 76 trim units are found under the "accessories" tab for the 76 model year.
