1976 evinrude 85 hp rectifier charging battery.
F_R
Honorary Supreme Mariner
Re: 1976 evinrude 85 hp rectifier charging battery.
Of course.
1. Clip a voltmeter to the battery posts. Note the voltage.
2. Start and run the motor awhile. The voltage should slowly increase as the battery charges.
EDIT: I just noticed your other thread. Get that thing running first. One thing at a time.
Vic.S
You can test the rectifier by following Joe Reeves' instructions on the Engine FAQs board.
BUT if you use a digital meter use the diode test setting.
Digital meters do not usually work for diode testing on the ohms ranges like anaolg meters do
