1976 Evinrude 70hp slipping
msu98
Started to slip when throttling up. Will trot along but as soon as I give some gas it slips and goes nowhere. Where do I start?
DMAN1968
Re: 1976 Evinrude 70hp slipping
Sounds exactly like what my motor did when I spun the prop. There is a rubber insert inside the hub of the prop. It is made to give when you hit something so as not to damage the lower unite/gears. Instead of the prop turning the shaft and rubber insert is turning. I just took mine to a local prop shop and they were able to press in a new hub for me...not very expensive. If you have a spare put it on and I bet you will see the trouble go away.
msu98
Thank you, took off the prop and the rubber was pretty chewed up. Looks like what the problem is, Thank you...
Benny1963
`HEY d man WERE YA AT IN BATON ROUGE
