The dripping may not be related to the performance issue, but I would think a proper carb rebuild would be a good starting point since you're leaking fuel. Order rebuild kits and do a complete teardown, including removing the welch plugs and removing the jets. Make sure all passages are clear - blow compressed air through. And have a really good look at all the rubber lines on a motor that old.
And if you don't know when it was last done, your purchase is a candiate for a water pump impeller. Just to be safe.
