1976 Evinrude 35, no spark/intermittent spark/weak spark.
Rootguitars
Things I’ve tried. New points, new condensers, new driver coil, new ignition coils, good used armature plate (bushing worn out on the old one), new plugs. Good continuity on wires from driver coil to ignition coils.
same problem after all those things . Don’t quite know what to try next. New to this or any forum so thanks for the help!
kbait
Ground lead (wire) from armature plate to powerhead missing or not connected? Faulty kill switch circuit?
Good luck!
Rootguitars
Good luck!
Thanks for the reply. Ground cleaned and properly connected. nothing Connected to a switch.
oldboat1
continuity of plug wires from coils to plug spring connectors?
