1976 evinrude 35 hp torques
mrcrw009
i have a 1976 35 hp 35602S evinrude and am looking for the torques for the connecting rods on the piston, the torque for the crankcase halves and the flywheel nut. any help would be greatly appreciated thank you
mrcrw009
Re: 1976 evinrude 35 hp torques
Does anyone know where i could find the torques minus buying the manual since i'm pretty much done with everything except putting it all back together?
Mohawkmtrs
Connecting Rod Screws - 30-32 ft/lbs.
Crankcase-to-Block Bolts (Main Bearing Bolts) - 12-14 ft/lbs.
Flywheel Nut - 100-105 ft/lbs.
mrcrw009
wow that much on the connecting rods huh. that sounds kinda high for that small of a bolt i think they are 1/4 28 bolts aren't they? (5/16 head anyways) anyways thanks for the info i will put it together this weekend.
