typhoid_iowa
Thread starter- Joined
- Aug 2, 2010
- 4
Greetings!
I have been putting together/rebuilding/replacing a 1976 Evinrude 25hp I bought a couple years ago for my little tin boat. The motor hasn't been run for at least 2 year, more likely 5, since the guy I bought it off of bought it as a parts motor (was originally missing the lower unit, but he found a suitable replacement.) So I've had my fair share of run-ins with little demons throughout this project. But, the motor was the right price, and I love to tinker... so if I can make it useable, its a win in my book!
Anyhow. This morning I set out for the maiden voyage on this old outboard, and had a couple of issues that forced me to pull the boat back up the hill and swap it back to my 9.9 just to salvage the day on the water:
1) I was able to choke and start the motor, and it would idle up as it should (with the choke on.) However, after releasing the choke, it would cough and die. I reset the idle mix screw to both the 1 turn out (as I have read in a few different places,) and also the old tried and true 1 1/2 turns out. Neither of which would proved to make much of a difference.
2) The motor would run if it wasn't at idle, but it smoked excessively. And by excessive, it acted like it was running almost purely on 2 cycle oil. I know the mix was right and it wasn't an issue with the oil separating as the 9.9 didn't smoke at all and started on the first pull.
3) It is pumping water, but it still seems to me that it is running kind of hot. When running, the exhaust housing is very warm to the touch. I know that it doesn't have a thermostat in it (as I was surprised to open the cap to the head and not see an old, corroded thermostat in there.)
Now, just to save a little troubleshooting time, here is a list of what I have done to this machine:
When I started with it, the compression was within 5 lbs on both cylinders (can't remember the exact numbers)
Full carb rebuild
New Fuel pump diaphragm and screen
New fuel lines
New plugs (Went to the OEM spec J4J, had J8 plugs in it when I got it, not sure if I made a mistake there...)
New impeller
All new lower unit seals
Plus a fair number of other parts, since 30+ year old plastic just doesn't cooperate that well...
I've had this motor running in a barrel before I ever put it on the boat, but my barrel size was limited, so I never had a chance to really put this motor in gear and get it up to full throttle before. It has always had the "cough" to it, and it is almost like a typical lean cough, but I can't seem to correct it. And it always smoked quite a bit. I just attributed it to not being ran for so long, it might need a good kick in the pants to clean it out.
So now I'm stuck. Any help would be greatly appreciated, as I would like to know if I'm in a losing battle. I'd hate to sink anymore money and time into this... and I'm sure my wife would hate it more than I would
Full carb rebuild
New fuel lines
New impeller
