1976 evinrude 20 Hp (model#206B62D) replacing water pump
chris206B62D
Hi,
I am working on replacing the water pump on my 1976 evinrude (model #206B62D). I have removed the lower screw on the shift linkage behind the exhaust plate, with the motor in forward position. When I try to pull out the lower unit there is something stopping it. I can only get it out 3/4 inch. Any ideas what might be stopping the lower unit from coming out?
F_R
Honorary Supreme Mariner
Drive shaft splines are stuck in the crankshaft. All because the last guy left a 50 cent o-ring out.
oldboat1
Is the lower shift rod fully released from the brass connector? Sometimes they are clamped in place even after the bolt is removed -- need to be nudged. If the driveshaft is stuck in the powerhead, you might be able to use a flat pry bar or something similar to free it up, working from side to side. Probably missing O-ring at the top of the drive shaft, like F.R. mentioned -- particularly nasty if a salt water motor. Will need to clean up the splines when you get it out (Use some marine grease when reattaching, used sparingly and avoiding the top of the shaft.)
I don't think a 20 was made after about '73, btw, so you might have an earlier model.
chris206B62D
Thanks for the guidance. The shift rod appears to be fully released, I can see if moving out of the brass connector when I pull the lower unit down and used a small pry to gently move the shift rod inside the exhaust opening. The motor has only seen fresh water, so hopefully some gently prying will do the trick.
F_R
Just wondering, I haven't been able to find that model number listed. Is it a commercial motor or something? Country of manufacture??
The 20 hp was marketed in Canada in the early and late 1970's !
Jdude1
you may need to make sure it is in neutral I have a 76 Johnson 25 hp had to loosen both shift linkage bolts almost all the way as well took some prying but I got mine apart.
Only one bolt needs to be TAKEN OUT of the shift rod connecter.-----Use small pry bar on top of water pump housing to slide it apart.
chris206B62D
The motor was made in Canada, I believe it was purchased in British Columbia. I used a pry bar and gentle pried side to side and the lower unit cam off. Impeller has some good wear on it. New parts coming in today.
As clearly stated the 20 HP was marketed in Canada for those years !!
hardwater fisherman
Just below the splines on the top of the driveshaft there should be groove where a rubber o-ring goes.
chris206B62D
The water pump is replaced. While prying the lower end off, the impeller pin cracked the water pump housing, which was ok as I ordered a whole new water pump kit. The drive shaft was really seized. I used a penetrating oil, which worked. Once the driveshaft was out, I noticed that the o-ring was in place. The new water pump was simple to install and the lower end was back on the motor. Once I fired up the motor, plenty of water was coming out, more than I had noticed in previous years. Thanks for the guidance and support.
chris206B62D
Yes, I greased the splines and used a new o-ring. The water pump kit came with a small grease envelope that I used.
