Well I just got the motor today, here is what I found.
note: the guy told me it was firing only on 1 cylinder.
1. the first thing I checked was the spark plugs to see if they were getting spark and both were, which was weird.
2. there is a small chip out of the flywheel, about half an inch.
3. I was going to inspect the ignition components under the flywheel but couldnt get it off with my puller. I tried for a couple of hours and gave up. One of the threads has been stripped, but had threads down in there, so I could get a bolt in there, it was just rough at the top. I tightened, knocked, tapped, tightened till it wouldnt tighten any more. I will have to mess with that later.
4. the screen in the fuel pump has some red, rusty looking stuff in it. maybe its what gas looks like when its dried up, I dont know. I cleaned that with carb cleaner and sprayed a bit in the fuel pump.
now, i was going to wait and clean the carb and put a new impeller in, but I couldnt stand it. I loaded it up and took it to the lake.
It started on first pull choked, and then started on next with no choke. Idled down real quiet.
it ran good at top end and sounded good, but there was a couple of problems I found.
when I twist the throttle all the way down, it will die. Come to look at it though, when its twisted all the way to slow, the cam is not even touching the roller from the carb. Is that correct?
when its throttled down, should the cam actually loose contact with the roller because it goes over so far?
