1976 Evinrude 15hp carb rebuild!
merkdawg0084
Does this need to be removed to do a carb rebuild? Or can I just run a small wire in the opening and compressed air? Thx
A wise man would take a big screwdriver and remove that in seconds.
merkdawg0084
I’ll do it first thing in the morning. Thx. You guys have a rebuild kit #?
merkdawg0084
I found the carb kit. What is this plastic piece and where would it go in my carb? Or is it for another model? Thx
JohnnyGuy
That would be the needle bearing for the low speed needle. SOMETIMES they will come up when you remove the slow speed needle.
I am not as experienced as others around here so they may have recommendations for removing the existing bearing...
I have not replaced it when it has not come out with removal of the needle.
merkdawg0084
Don’t think so. When you take the slow speed needle out there is a rubber like bushing that goes in there to keep tension on the slow speed needle.
F_R
The small round plastic part is the slow speed needle "bearing". It goes way deep in the hole, where the straight part of the needle resides. Bearing is sort of a misleading name, It actually is a "seal" to prevent air from sucking in past the threads. I had a home-made puller to get it out, back in "The Day". Others have used some sort of a hook. Others have used a drywall screw. Others have just left it alone and hoped for the best.
The friction bushing is the larger part with a tab on one side, at the entrance to the needle.
Tim Frank
It looks like a "not-so-wise-man" already took a small screwdriver to it. and may or may not have been able to get it out. :)
Make sure you use a screwdriver that is snug in that slot. Or grind a small right-size rectangle of steel to fit snugly and turn with vice grips.
That brass is soft enough that it can tear up and then it will be tough to remove.
merkdawg0084
Yessir Tim. I was the not so wise man, but I found my BIG screwdriver and got it out . Thx
Tim Frank
Another "not-so-wise-man" did that to one of MY carburetors, and it was a nightmare getting it out....had to destroy it to accomplish.
That is how I knew.... :)
