1976 evinrude 140hp 2 stroke will not go into forward gears
Glastron 176 1976
Got a question here about my 76 evinrude 140 last weekend we were out on the lake cruising around. I came to shore to adjust the floats on my carbs. When to take off and no forward gears cables were moving as they should but it just made a clicking noise from the engine I reached over and manually shifted it and i t when in gear and went about 4 foot popped out of gear and will not ingage no matter what u do I used reverse to get back to shore which works fine. Is the lower unit done or is there a way to repair it I had just changed the lower units out with a gl-5 compliant lower unit lube
