1976 Chrysler 135 HP Timing
canemode
Can anyone tell me the correct timeing settings for this motor at idle please.
scotiany
Re: 1976 Chrysler 135 HP Timing
Info I have says Champion UL18V plug, 32 deg BTDC for timing at WOT. Idle RPM 700-750. Should have the Magnapower type II igniton sytem. <br />Source: Seloc manual.<br />At idle, I would think the timing would be around 0 deg BTDC. Timing is set at WOT only as far as I know.
Terry H
If you can get yourself a Seloc or other manual it will tell you exactly how to set the timing. It's important to have WOT timing close on these motors, between 28-30btdc...just a thought :)
