1976 75 HP Johnson Tilt / Trim Wiring
dkski
I have just purchased a new 2 wire motor to replace my old 3 wire motor that was totally rusted up. My question is where can I get the wiring that connects to the tilt motor and does it run from the outboard motor to the battery then a switch or? I have included a picture of the motor I bought. Can't seem to find the information anywhere.
Thanks,
Dave
tashasdaddy
Re: 1976 75 HP Johnson Tilt / Trim Wiring
two wire and 3 wire are not compatible, you need a 2 wire relay box. the 3 wire has up and down wire, plus the ground wire, the 2 wire uses reverse polarity for the direction the motor runs.
