1976 70 hp evinrude won't idle down now.
dave2
My 76 hp Evinrude just quit when advancing throttle.
iggyw1
Ensign
This will not be enough information to get any help on here from the guys that would know. They want to know if you did a compression check. If so what were the readings? Did you check the spark to see if it will jump a 7/16 gap? What is the model number of your motor? Did you perform any trouble shooting on your motor? If so, what did you try? Did you squeeze the primer ball when the motor was running to bypass the mechanical fuel pump? They need the answer to their questions if you really want them to help you out. They helped me a lot through the past couple of years, and that's because I gave them the info they wanted and I did what they suggested to me. Good luck my friend.
