Issue: When top plug wire was disconnected the motor would die. Comp test shows 120 on both cylinders. has two new (two week old) coils and plugs. I bought a spark tester and the top showed no spark at all. I pulled the fly wheel and knocked of the carbon from the magnets on the flywheel, sanded and reset the points to .20. Now, neither wire is producing a spark.
NOTE: While pulling the plug wire the spring-like connecter came loose from the plug wires (both), I reinserted the pin that juts from the connector back into the wire and slid the wire back down into the boot.
Also, the magneto looked to be intact but I took sand paper to the ends where they are closest to the fly wheel. It is shaped like an M and I sanded down the left, middle, and right. (Got a bad feeling about that one)
Could one of these two issues be the problem? If not, how can I work my way backwards to find the problem? I do get a back fire every now and then while trying to crank the engine.
