1976 ---135 evinrude no fire on 2&4
kcboat
has been setting for 3 yrs.new plugs and fresh gas.always ran carbs dry of gas when finished.started on muffs,hard to start but seamed to run fine.put on water hard to start and will not high idle. would only run half throtle.120 psi cimpression all cylinders.no fire on 2&4.sensor coils,charging coils,ignition coils all check good with ohw meter.power pack replaced aprox. 6 years ago. power pack again??????
emdsapmgr
If you check out this website: cdielectronics.com, you will find some excellent ignition troubleshooting information. This includes specs for minimum voltages from the stator, and timer base when the engine is being cranked. Many of us prefer to validate these ignition components by their voltage ouput instead of using ohm meter readings. Start your trouble shooting here, first. You will need a special voltmeter, called a DVA, as a normal household conventional voltmeter won't read these voltages properly.
