1976 115 Evinrude
Pontooncowboy
Having issues with the 3 and 4 plugs fouling very rapidly. 1 and 3 are burning perfect. Just replaced powerpack that was bad and have removed carbs and cleaned. Even replaced lower carb with extra one that I had. Engine will run, but when you gas on it to take off, you can feel that it just isn't topping out. What am I missing here that could be causing problems? Compression is 118 to 120 on all 4 cylinders.
Top 2 cylinders , # 1 and #2 are fed by the top carburetor.-----Does spark jump a gap of 1/2 " on all leads.-----Are wires FROM the pack going to the correct coils ?
Pontooncowboy
Yes they are going to the correct coil . I have an inline spark tester and they have the same spark across the board. The only thing I haven't done to the carbs is a full rebuild kit. I did a quick clean but didn't remove any of the jets. Is it possible that a jet is clogged?
Did you find dirt or dried up fuel in the carburetors ?-------Checked the fuel pump diaphragm ?----Checked reed valves ?
