Re: 1975 volvo AQ225A cracked exhaust riser
What did you pull? the riser? The exhaust will get hot, especially if your running on muffs. One may get hotter than the other, that's normal. Still waiting for a usefull temp gauge, even an IR thermometer can be useful, got one?
If the flow is being slowed by corrosion, there's not much you can do. Im not saying yours is clogged, but you can't clean them out, backflush.
If there is a plug in the bottom of the mani, at the back you could try pulling that and seeing if its clear. My manifolds had a bunch of sand in it from swallow water boating...
