1975 Sears 7.5 help!
JonBoatBassFisher
I have a 1975 Sears Gamefisher (eska) 7.5hp outboard. I can get it to run for about 20 seconds at the most but it just bogs out after that even though it still has gas in the tank. I have rebuilt the carb and have parts for a second rebuild if needed. Here is a video of what it does. Thanks for any help.
M
mrcrabs
Guest
Re: 1975 Sears 7.5 help!
was that a old muffler? sounds like she just run out of gas...check your flow to the bowl and then float level
JonBoatBassFisher
It is still getting plenty of gas to the carb. Enough to where once it cuts out, I have to cut the fuel flow off because it will overflow out of the carb after like 15 seconds. I've never worked on a carb with a float so what do you mean by check the float level? Also, I am running 50:1 gas in it but I read somewhere that I should be running 32:1 on my model number, is this true? Model number is 217.585910.
M
mrcrabs
Guest
Well then you should check your orange fuel pump bladder for a split, but first you need to reference the Tecumseh engine /carb manual to get a general understanding and the spec's for your carb settings....it will really help you tune your engine and give you a detail on how to set your float. Do a search here at Iboats or google and you should find a link for this very common but "can't live without" Tecumseh manual.
As far as the fuel mix it is 32:1 but I wouldn't be to concerned due to the fact that Tecumseh was all over the place on mix ratio's around 1975, you have a 640-07a engine and this production number marks a change in bearing and rod design to the stainless steal insert and 32 needle rod bearing and aluminum Rod in the 640 series of 2 cycle engines, before this they used a forged steel rod and 66 split needle's and ratios were anyplace from 24:1 to 50:1.
I have one of those 66 bearing models and I run 50:1, 40:1 and sometimes 32:1 basically anything I have mixed up, and other than smoke theres really no performance diffrence except maybe a fouled plug now and then, we have a better burning 2 cycle oil these days so 50:1 is Ok for you outboard but if your worried make it 40:1 and use synthetic.
