1975 Searay 240SRV lost all power
DansSearay20111
Had the radio running and killed my battery. Switched batteries out but when I did I accidentally mixed up the positive and negative. Had a third battery that was charged and hooked that up but now I have no lights or anything that works. Can someone tell what I would need to check? Where are the fuses? I did check the main 20amp fuse off the battery but its good. Where else do I look?
25thmustang
Re: 1975 Searay 240SRV lost all power
Is there an AC/DC panel in the cabin of the boat? Mine has fuses down there, as well as at the helm for the switches on the dash.
DansSearay20111
I did look at the control panel under the dash and checked any fuses I saw. What I found as far as fuses in the dash were good. Is there more than one fuse going to the duel battery switch? Is there a fuse between the duel switch and the front of the boat?
Silvertip
Honorary Supreme Mariner
Reversed polarity usually pops a fuse or breaker in the engine bay. If this is an I/O you may have toasted the alternator as well.
DansSearay20111
Yes its an I/O. I already new the altenator has not been working well and part of the reason I having battery issues but I know this was a stupid mistake and careless. Where would the breaker be? I knew to boating and especially the wiring in the boat. Where would you start trouble shooting?
Grand Larsony
Red button either on engine block or on firewall forward of engine room. Push it in.
DansSearay20111
If the circuit breaker blew would that still effect the alternator? Isn't that the reason behind having a breaker? Someone posted earlier that I could have toasted the alternator. If I did can I just go to a Auto parts store and pick up a new alternator or do I need a marine version?
Grand Larsony
Marine version ONLY or you go BOOM.
Take it in, have it tested (at auto parts store) and possibly rebuilt if needed.
rbh
Hi Dan-
First off the alternator must be a marine type due to the fact that it could be in an gas vapour enviroment and the marine types are sealed (sparks and all)
second, when you removed the cable or cables off the battery did you forget to hook any of them back up??? Sometimes you will find that the acc power is drawn off by means of smaller cables with ring crimps on them.
And as was mentioned there is a red button (circuit breaker on a mercruiser engine)
push in to reset.
DansSearay20111
I am pretty sure I had everything hooked up. I been having battery issues since I purchased the boat so I have to charge the battery a few times. I will double check tonight when I get home. Where would the reset button be on the motor? Thanks everyone for the input. Hopefully its just the reset button. One thing I did noticed that kind of confused me is my trim still worked but nothing else. Would the trim pump be separate from the main harness? It would only go down and not up.
rbh
You usually have the bilge pump (automatic float) and the trim pump directly hooked up to the battery.
If you have a mercruiser engine (v8 ETC) there should be a group of wires just above and to the left??? of the water pump pulley (starter slave solinoid) and thats were the "RED reset BUTTON" should be.
